Global variabel
I have declared a couple of global variables in my main program and can access these values from another module which I load with the load command. However I cannot set these variables from the loaded module. How do I do that? I have the following code:
Module mod1
PERS bool red := FALSE;
PERS bool black := FALSE;
PERS bool green := FALSE;
PROC main()
LOAD "C:/folder/file.prg";
%"paintprg:callMe"%;
UNLOAD "C:/folder/file.prg";
ENDMODULE
MODULE mod2
PROC callMe()
red := TRUE; ! This doesn't work
ENDMODULE
Why won't that work and how should I do to solve it?
I recommend you to use .MOD files for your modules.
In your example, file.prg should be Mod2.mod
I usually use a module containing only the PERS variables, such as:
MODULE Globals
ENDMODULE
Then a small module that loads the most of the code, such as:
MODULE StdTask
PROC Main()
LOAD "C:/folder/modmain.mod";
red:=FALSE;
TPWrite "Now red is FALSE";
%"MainEntry"%;
IF red THEN
TPWrite "Now red is TRUE";
ENDIF
ENDMODULE
And the main module
MODULE ModMain
PROC MainEntry()
red := TRUE; & nbsp; ! This will work
Save "GLOBALS.MOD"; ! Not recommended, but legal
ENDMODULE
Saving Globals.mod will save new PERS values in the file, that can help if you P-Start the controller very often. But do not write to often on the flash-disk or you can damage it (so I've been told, even if it has never happend to me).
claudio2007-3-29 9:27:291 -
Can I load a module without an absolute path? Does it understand relative paths or environment variables?Actually full path gives meSystem1/RAPID/T_ROB1/Module1(280,14): String too long(141): The string LOAD is too long. 12/07/2019 2:51:29 PM General
Post edited by kschmid on0 -
I believe that the real problem lies in the parentheses.Lee Justice0
Would you recommend adding parentheses?
I am using windows syntax with backslashes (path has spaces as well) ... Not sure it matters?
RemoveDirWithContent("HOME:/Test");Where does HOME point to or how do i set HOME ?This is interpreted as the path to the home directory of the current system.
Ah, folder below your system (in controller tab) ...Loading more than once is bad, can I check loaded?0
Yes, use ModExist.Lee Justice1
