array of variable size as function parameter
kschmid
Whats the syntax to pass an array of variable size as function parameter?
Ah and is here a "size of" operator on an array?
Hello,You can write parameter like this:
PROC MyProc(string pstrArray{*})And then get its size with:vnSize:=Dim(pstrArray,1);
☑️2024 - RobotStudio® User Group1
