Show all errors when you Apply in RAPID editor
in UpFeed
Is it possible to show a complete list of error when you apply changes in the RAPID editor instead of showing only the first?
Right now the Output window only shows the first reference/syntax/assignment error. When you correct it and hit apply again it shows the next. It would be nice it if showed all the current errors like most PLC programming software does so you can apply, fix all the errors, and apply again.
Thanks, Jon
Thanks, Jon
Hello,Syntax error often breaks under code lines.In RobotStudio editor, you can easily show error with red underlines.
☑️2024 - RobotStudio® User Group0
