User frame Z offset in workobject isnt displayed in targets in viewport properly
kschmid
hi,
I added a z offset in the user frame for the workobject's user frame.
It works correctly in simulation but the targets in viewport arent drawn with it so they look too low.
Probably a known bug is there a workaround/fix?
Also, syncing existing targets is unreliable. Any tricks?
I would say that's an issue. For example MoveLGO or RelTool are also not displayable.
1 -
Would be great to fix, i am spending a lot of time guessing whats wrong
Can you post an rspag and/or more detailed description?Johannes Weiman
Not in public, do you have an email?
- 365 IRC5
- 84 OmniCore
