Station Logic delete I/O Signals from Controllerbox
Hey Everyone,
Is it possible to delete the Signals at the Controller Box in the Station Logic? I don't want to delete the Signal in the I/O System, just in the Station Logic at the controller box (highlited signal in the picture below). From the drop down menu you can choose a signal. But when you have it in your Controller Box I find no way to delete it again.
Thank you
Hello,Signals are keep until you restart your station.☑️2024 - RobotStudio® User Group0
Hey Denis,but is it possible to delete them in the Station logic from my Controllerblock (picture above) without deleting it from my I/O System. There are signals on my controllerblock I don't use anymore in my station logic. But I want to keep them in my I/O System. To make my bindings in the station logic clearer, I want to clear the unused signals from my controllerblock.Thanks0
ok, sorry. I got it Denis. A restart of Robotstudio works. A restart of the controller is not enough.Problem solved,thanks.0
Restart of RS is not needed. It should be enough to close and re-open Station Logic.
Johannes Weiman
RobotStudio Team, ABB Robotics0
- 365 IRC5
- 84 OmniCore
