User frame Z offset in workobject isnt displayed in targets in viewport properly
hi,
I added a z offset in the user frame for the workobject's user frame.
It works correctly in simulation but the targets in viewport arent drawn with it so they look too low.
Probably a known bug is there a workaround/fix?
  • Also, syncing existing targets is unreliable. Any tricks?
  • I would say that's an issue. For example MoveLGO or RelTool are also not displayable.
  • Would be great to fix, i am spending a lot of time guessing whats wrong
  • Can you post an rspag and/or more detailed description?
    Johannes Weiman
    RobotStudio Team, ABB Robotics
  • Not in public, do you have an email?
