Check for integer
YoDoug
I have a situation where I need to check to see if a calculated num value is an integer. I am struggling to find an easy way to do this. Suggestions?
:=(Trunc(
<code>numValue
)=<code>numValue
<code>bIsInt
Try NumToStr, then StrMatch for a ".", the decimal.Lee Justice0
RAPID offers the instruction "TryInt" to check if a number is an integer.<p>VAR num myint := 5.2;</p><p><br></p><p><b>TryInt</b> myint;<br></p><p>ERROR<br></p><div><p>IF ERRNO = ERR_INT_NOTVAL THEN</p><p><br></p><p> myint := Round(myint);</p><p><br></p><p> RETRY;</p><p><br></p></div><div><p><span>ENDIF<br></span></p></div>
/BR
Micky1
- 345 IRC5
- 73 OmniCore
- 844 RAPID Programming
- 20 AppStudio
- 108 Collaborative Robots
