Show Work Envelope doesn't work
I'm working in RobotStudio using the IRB 14000 and the option Show Work Envelope is not enabled, why?
Thank you
RPereira
Thank you
RPereira
The work Envelope of IRB 14000 is not implemented in RS at the moment. This is planned for end of 2016.
1 -
At the moment this is not implemented in RobotStudio - it is planned for the release at the end of 20161
Should this work now? Because i'm working with YuMi and the "show work envelope" button is not click-able
No, Yumi work envelope is not supported.
Johannes Weiman
RobotStudio Team, ABB Robotics0
- 367 IRC5
- 858 RAPID Programming
