Debug an application running on robot studio
I have developed a c# application that can be executed in the flex pendant. Is possible to execute in debug mode the application using the virtual flex pendant? I try to start the virtual flex pendant and connect the solution (from visual studio) to the process VirtualFlexPendant.exe, but I can't insert a breakpoint of see where is the program pointer.
Anyone have a suggestion?
Thanks in advance.
Nicola
