RW6.08 with SafeMove and SC_CBC task
DenisFR
DenisFR ✭✭✭
When I do Backup, the controller switch task number between SC_CBC and T_ROB1, in virtual controller too.
How can I fix it?
  • I experience the same problem. Did you ever find a solution to this?
  • DenisFR
    DenisFR ✭✭✭
    No, sorry.
  • I am also facing this issue. The backup is not filled with the modules due to a "file access error" which originates from a sudden SC_CBC task trying to access a wrong directory.
    Still no hint from ABB moderators ?
