RW6.08 with SafeMove and SC_CBC task
I experience the same problem. Did you ever find a solution to this?
No, sorry.
I am also facing this issue. The backup is not filled with the modules due to a "file access error" which originates from a sudden SC_CBC task trying to access a wrong directory.
Still no hint from ABB moderators ?0
