"Connecting to the robot controller "
Ey guys i have an issue on my ABB robot , when i turn on my flexpendant appears "Connecting to the robot controller".
Does anybody know how can i fix that ?
Hello,Did you change your WAN IP?Don't use 192.168.125.x, 192.168.126.x nor 192.168.127.x.☑️2024 - RobotStudio® User Group0
any other help?I have same issue.I removed some Profinet device and after restart pentand stop on "Connecting to the robot Controller"...0
Check connection to main computer ethernet port for pendant. Check status lights for same.Lee Justice0
