weld with torch still
Hello everyone, I should weld a tube mounted on a rotating external axis.
Is there a way to weld with the torch still?
I tried using an ArcLstart and an ArcLend with a waitime in the middle but without result.
Can anyone help me?
Thank you.
Roger
Roger
