receive whole numbers with decimals (positive and negative)
Escribe tu meI want to receive whole numbers with decimals (positive and negative) of a PLC through IP Ethernet communication. My controller is an IRC5.
Someone here has experience in that applicationnsaje
  • Hello,
    You can use analog signal where you set maximal and minimal values.
    What I use with ProfiNet:
    &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; -Name "AiOffS_X_T1TB1" -SignalType "AI" -Device "PN_Internal_Device"\<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; -DeviceMap "208-223" -MaxLog 327.67 -MinLog -327.68
  • LOERAM
    LOERAM
    edited September 2019
    THE ANALOG SIGNAL DOES NOT REFER TO A PHYSICAL OUTPUT OR INPUT TO WHAT I UNDERSTAND WITH YOUR EXAMPLE THAT ALSO WORK AS A VIRTUAL ANALOG OUTPUT OR INPUT. IT IS RIGHT?
  • Map it to your device and it is a real signal, this was just an example for you.
    Lee Justice
  • Thank you
