receive whole numbers with decimals (positive and negative)
Hello,You can use analog signal where you set maximal and minimal values.What I use with ProfiNet:
-Name "AiOffS_X_T1TB1" -SignalType "AI" -Device "PN_Internal_Device"\<br> -DeviceMap "208-223" -MaxLog 327.67 -MinLog -327.68
THE ANALOG SIGNAL DOES NOT REFER TO A PHYSICAL OUTPUT OR INPUT TO WHAT I UNDERSTAND WITH YOUR EXAMPLE THAT ALSO WORK AS A VIRTUAL ANALOG OUTPUT OR INPUT. IT IS RIGHT?0
Map it to your device and it is a real signal, this was just an example for you.Lee Justice0
Thank you0
