SearchL - continue when error
Hi All
I have a small problem,can someone help me with this?
        WHILE di_ready = 1 DO
           SearchL\Stop
        ENDWHILE
        ERROR
           IF ERRNO=ERR_WHLSEARCH THEN
        ENDIF
All i want is to continue with program after error of search.... Now everytime when IF ERRNO end robot stop and rise alarm on pondant...  Can someone help me with this?
  • You should look into CRobT(), maybe use it to make an offset or reltool move to try again, if that is what you are asking for help with.  Also, look into Retry or Trynext  You could also RAISE the error to the routine from which it was called.  Error handler in that routine should most likely have Retry.
    Lee Justice
  • As Lee says above use the Trynext in your error handler - this will continue with the next instruction after the one that cause the error.
