How to add robot model?
hi guys i installed new robotstudio version
but i just choice robot model in picture
how to add robot model?
can you give a solution?
  • These are the only robots that support RW7 at present.
    Go to the addins tab and add RW6.10 then you will be able to select from the rest of the robot range.
  • Thanks graemepaulin! have a nice day!
