Send robot position from a semi-static background task through socket communication
I am trying to send robot position data [X,Y,Z] only through socket communication from a background task.
My procedure for setting up socket communication is as follows: (This is inside main() module)
I am trying to reference "server_socket" defined in main module of foreground task in background "robPos: task. I am getting a syntax error. Server_socket variable is not visible in scope of robPos task. How can i solve this?
PERS bool socketActive := FALSE;
PROC Setup_Socket_Comm()
! WaitTime to delay start of client
! Sever application should start first
WaitTime 5;
SocketCreate server_socket;
! IP address of server/slave (PLC) is xxx.xxx.xxx.xxx
SocketConnect server_socket,"xxx.xxx.xxx.xxx",1025;
! Communication start
SocketSend server_socket\Str:="Hello PLC#";
SocketReceive server_socket\Str:=received_string;
TPWrite "Server wrote - "+received_string;
! Set socket active flag
socketActive:=TRUE;
! Error handler to make it possible to handle power fail
ERROR
IF ERRNO=ERR_SOCK_TIMEOUT THEN
RETRY;
ELSEIF ERRNO=ERR_SOCK_CLOSED THEN
SocketClose server_socket;
! WaitTime to delay start of client.
! Server application should start first.
WaitTime 10;
RETRY;
ELSE
TPWrite "ERRNO = "\Num:=ERRNO;
Stop;
ENDIF
ENDPROC I have created a new semi-static task called "robPos". Is it possible to reference a socket variable created in foreground task by a background semi-static task? My "robPos" task has following content:MODULE robotPos
! Shared Global Persistant variables with tasks
PERS bool socketActive:=FALSE;
VAR num xpos;
VAR num ypos;
VAR num zpos;
! Socket comm
VAR string received_string:="";
PROC main()
sendRobPos;
PROC sendRobPos()
VAR pos currPos;
VAR string str_x:="";
VAR string str_y:="";
VAR string str_z:="";
WHILE (socketActive := TRUE) DO
! Get current robot position
currPos:=CPos(\Tool:=tool0\WObj:=wObj0);
xpos:=currPos.x;
ypos:=currPos.y;
zpos:=currPos.z;
!Dont forgetaddition of termination character (#)
str_x:="x"+NumToStr(xpos,4)+"#";
str_y:="y"+NumToStr(ypos,4)+"#";
str_z:="z"+NumToStr(zpos,4)+"#";
SocketSend server_socket\Str:=str_x;
SocketReceive server_socket\Str:=received_string;<br> IF (received_string="ack") THEN
! Ack recieved
SocketSend server_socket\Str:=str_y;<br> SocketReceive server_socket\Str:=received_string;<br>
! Ack recieved
SocketSend server_socket\Str:=str_z;<br> SocketReceive server_socket\Str:=received_string;<br>
! Ack recieved
! All good
ENDIF
ENDIF
ENDIF
ENDWHILE
ENDPROCI am trying to reference "server_socket" defined in main module of foreground task in background "robPos: task. I am getting a syntax error. Server_socket variable is not visible in scope of robPos task. How can i solve this?
I am curious as to the construction of the beginning of your WHILE instruction:
It is my understanding := means assign.
Are you sure you don't mean
WHILE socketActive=TRUE DO
?1 -
Oops, yes that's a typo. It should be =SomeTekk said:I am curious as to the construction of the beginning of your WHILE instruction:WHILE (socketActive := TRUE) DO
Can socket variables declared in another task used in a background task?0 -
Ought to be if they have the same name and are declared as PERS.Lee Justice0
I tried this. I get an error saying that the datatype "socketdev" used to declare "server_socket" can't be of type persistent.lemster68 said:Ought to be if they have the same name and are declared as PERS.
This gives me an error when added to background task:PERS socketdev server_socket
it looks like it can only be declared as a variable
VAR socketdev server_socket
The manual says that socketdev is a non-value datatype
Oops! But anyway, why would you also need it in your main task if the background task is doing the job?Lee Justice0
The main task is sending different parameters (these parameters are embedded in the main task rapid code and these parameters are sent at particular motion events).lemster68 said:Oops! But anyway, why would you also need it in your main task if the background task is doing the job?
Is it possible to have two socket connections to same server (PLC) with same IP address but different ports? That might solve the problem
I think, just different socketdevs.Lee Justice0
so create two socketdevs, one in main task and another in background task? Can they connect to the same server (same IP address) but with a different port number?lemster68 said:I think, just different socketdevs.
Manual says it is possible to have a max of 32 simultaneous socket devices at a time0
- 363 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
