Trigger two DO's 2 seconds from point
How can i trigger two DO's using a TriggL move?
  • The following example illustrates the instruction TriggLIOs:
    VAR triggios gunon{2};
    gunon{1}.used:=TRUE;
    gunon{1}.distance:=3;
    gunon{1}.start:=TRUE;
    gunon{1}.signalname:="DOutput1";
    gunon{1}.equiplag:=0;
    gunon{1}.setvalue:=1;
    gunon{2}.used:=TRUE;
    gunon{2}.distance:=3;
    gunon{2}.start:=TRUE;
    gunon{2}.signalname:="DOutput2";
    gunon{2}.equiplag:=0;
    gunon{2}.setvalue:=1;
    MoveJ p1, v500, z50, gun1;
    TriggLIOs p2, v500, \TriggData1:=gunon, z50, gun1;
    MoveL p3, v500, z50, gun1;
    The signal gun is set when the TCP is 3 mm after
  • Hi Slokko,
    Thanks for your answer.
    Is it also possible to use time instead of distance?
  • Time is an optional argument for the move instruction.
    Lee Justice
