Application Spot Welding is not functioning
eKoh
Hi! I want to work with the Spot welding technology.
But as I added this technology and had a Warm start.
The "Processes" tab in Configuration tab doesn't appear. Neither the SWUSER module appears.
I don't know what I am missing here. Btw this is the first time I do it for Spot welding, I have done this with Dispensing and AW before with no issue.
I am using RS 6.08.
Thank you for helping!
I am using RS 6.08.
I think you also must add one of the options Spot Pneumatic, Spot Servo or Spot Servo Equalizing.Johannes Weiman
RobotStudio Team, ABB Robotics0
