10129 program stopped error
in IRC5
I have this error
In the past I turned off power and turned on again. The error was cleared.
but now The error was not cleared. What should I do to clear this error?
I connected with RS software and checked " event log " there is10129 program stopped error. what should I do for solving this problem?
Might have happend because the programm stops for whatever reason in an event routine.That is something the controller can't handle.Maybe you are waiting for some I/O there.0
my event routine is empty. there isn't any setting in it
If you are not using the event routines - try removing them to see if that sorts it out.
- 341 IRC5
- 69 OmniCore
- 840 RAPID Programming
- 19 AppStudio
