10129 program stopped error
I have this error
  In the past I turned off power and turned on again. The error was cleared.
but now The error was not cleared. What should I do to clear this error?
I connected with RS software and checked " event log "  there is
10129  program stopped  error. what should I do for solving this problem?
  • Might have happend because the programm stops for whatever reason in an event routine.
    That is something the controller can't handle.
    Maybe you are waiting for some I/O there.
  •  my event routine is empty. there isn't any setting in it
  • If you are not using the event routines - try removing them to see if that sorts it out.
