Oculus Rift S controller *VR*
dyorcy
Is the Oculus Rift S controller supported for the station logic VrHandController in Robotstudio 2019 ? When i start VR in robotstudio and trigger (the left or right controller) trigger button nothing happens in Station Logic VrHandController left/right. I also did it with the HTC vive pro without any problem.
Hi, I have Oculus Rift s and there is no problem with station logic and could customize and use it. What is exactly your problem? I think, there is only one problem in Oculus Rift s , that can not use the WALK button in controller!!
- 367 IRC5
- 858 RAPID Programming
