Production Manager, calling "Part Handling" menu
jawojtek
Hello.
I need to call the "Part Handling" menu from my application so to make a kind of shortcut.
There is a PMgrRunMenu procedure - can I use it? What are the parameters, then?
Thanks for any help,
Wojciech Wlodarski
PLABB
PLABB
Are you using .NET application and PC SDK?
Did you found a solution?0
