Monitor I/O XS14 AND XS15 in robot-studio software
hi every body. I connect 24V sensor to X14S (IRC 5  CONTROLLER ). Where can I monitor this input   in robot-studio  software?
  • What version of IRC5, Standard, Compact, Panel Mount?
    Also, ABB, from time to time, uses the same designator (e.g. X5) in more than one location. Where, specifically, is the connection location internally or externally?
    Which RW version?
  • IRC5 Compact,
  • If you have the IO parameters setup you can view by right clicking on the IO System icon and navigating:
