Robinstall RW upgrade
Hello to all, is it possible to upgrade robotware version for Sc4+ system using RobInstall. If not what are our options for such operation. Thanks a lot in advance.
  • You use RobInstall to create the robot system using the appropriate RobotWare.
    It is then downloaded to the controller via Ethernet or floppy disks.
    You have to make sure (from the release notes) that your hardware is suitable for any upgrade.
  • Graeme is right about making sure your hardware is compatible.  You would need to install the newer baseware, make sure that it is in your mediapool.  Then, in roboinstall, select the system and edit it.  In this process you can update the robotware.
    Lee Justice
