Resetting Revolution Counters
in IRC5
Hey Guys,
I have a question in regards to resetting the revolution counters on a 6670. I was wondering if it is possible to reset 1 axis at a time, or does it have to be all 6. The end of arm tooling on the robot does not allow me to bring axis 5 all the way to 0, in hopes of not having to remove it, I wanted to do 1 axis at a time if possible but I can not see where I would be able to do that.
I was trying to move jobs from 1 robot to another robot (Both are 6670s, in an identical cell) In turn I lost the revolution counters. Any advice would be welcomed.
Thanks in advance.
Thanks in advance.
Best Answers
Sorry both robots are 6700s.0
No, you do NOT have to do all at one time. Just use the checkbox to select which ones you want to reset.Lee Justice1
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
