Asymmetric Zones?
Where do i find asymmetric zones when i use a Omnicore controller?
(I'm using RobotWare 7.0.01 and RobotStudio 2019.5.1)
1
Hi SuperCharger,Asymmetric zones and extended zone from/towards a finepoint is the standard behaviour in RW7.If you need to limit the zone, you can use the KeepStartPath/KeepEndPath optional arguments.
/M1
- 367 IRC5
- 858 RAPID Programming
