360 Degree View
P Diddy
Is there a way to do a fly through where the robot stays centered and you rotate 360 degrees around the robot?
I tried a fly through but as it goes around the robot it zooms in and out like it is dependant on the view center perhaps?
Thanks for any help that is available!!!
Hi P,
Here's some VBA code that does what you want. Just change the constants to suit your needs.
Sub RotateView()
' Constants
Dim lookAt As New Position
lookAt.x = 0
lookAt.y = 0
lookAt.z = 1
Dim rotateRadius As Double
rotateRadius = 4
Dim rotateHeight As Double
rotateHeight = 1
Dim step As Integer
step = 5 ' degrees
' Code
Dim view As view
Set view = Application.ActiveView
view.lookAt = lookAt
Dim lookFrom As New Position
lookFrom.z = lookAt.z + rotateHeight
Dim rad As Double
For deg = 0 To 360 Step step
rad = deg * 3.14159 / 180#
lookFrom.x = lookAt.x + rotateRadius * Cos(rad)
lookFrom.y = lookAt.y + rotateRadius * Sin(rad)
view.lookFrom = lookFrom
view.Redraw
Next deg
End Sub
regards,
Johannes
Johannes Weiman
Thank you for the quick response - I will see if I can get it to work.0
- 858 RAPID Programming
