How to protect programs from being copied?
How to protect my module from being copied (downloaded or written down via the Teaching Pendant) and operator still can edit other rapid ?
I want to protect my program without affecting the operator.
Best Answers
  • It should be a system module with attributes NOVIEW and NOSTEPIN.
    Lee Justice
  • Hi lemster68 ,j_proulxFB
    I tried your suggest.
    Output window show "Syntax error(136)Unexpected 'sysmodule' "
    Could you please give me some advice on this issue ?
  • Denis is correct, Module level, not PROC.  From the Rapid Kernel Manual: SYSMODULE | NOVIEW | NOSTEPIN | VIEWONLY | READONLY  These attributes must be in this order.
    Lee Justice
  • Also, I re read a little better the manual and see that NOVIEW should be the only one you need, because it excludes NOSTEPIN.
    Lee Justice
