GetTime with S4
Hello,Is it not more simple to transform all in one variable in minute unit?nTime:=nHour*60+nMinute;IF (nTime > 24) AND (nTime < 408) THENTPWrite "1";ELSEIF (nTime >= 408) AND (nTime < 1002) THENTPWrite "2";ELSETPWrite "3";ENDIF
I think that is pretty smart Denis.Lee Justice0
Hi.
I suppose I should supplement with...
VAR num nTime;
Yes.
Your If statement is looping around.
IF (nHour >= 0) AND (nMinute > 24) AND (nHour = 6) AND (nMinute < 48) THEN
TPWrite "1"; ELSEIF (nHour > 6) AND (nMinute > 48) AND (nHour < 16) AND (nMinute < 42) THEN TPWrite "2"; ELSE TPWrite "3"; ENDIF
Hi.
Now its working with time (all in minutes).
Less is more... :-)
Now I (we) continues with date.
VAR string date;
VAR num nDate;
date := CDate();TPWrite "Current date is: "+date;That's OK
But when I have test IF... I got problem
Maybe is below?stDate:=StrPart(date,1,2);bOk:=StrToVal(stDate,nDate);
Any idea?0 -
What part of the date are you trying to examine?Lee Justice0
Oh.Is it possible to have both day and month in same?0
Look up both CDate and Strpart functions in manual.Lee Justice0
Hi.
"Look up both CDate and Strpart functions in manual."
I cant find it in the manual.I've also tested some, but the program pointer always stop on
ex.:stDate:=StrPart(date,1,2);stDate:=StrPart(date,2,2);stDate:=StrPart(date,3,2);stDate:=StrPart(date,4,2);stDate:=StrPart(date,8,2);0 -
burtlib666 said:Hi.
ex.:stDate:=StrPart(date,1,2);stDate:=StrPart(date,2,2);stDate:=StrPart(date,3,2);stDate:=StrPart(date,4,2);stDate:=StrPart(date,8,2);FUNC string sToday() VAR string sTextYear; VAR string sTextMonth; VAR string sTextDay; VAR string sTextHour; VAR string sTextMinute; VAR string sTextSecond; VAR num nTextHour; VAR num nTextMinute; VAR num nTextSecond; sReadDateToday:=CDate(); sReadTimeToday:=CTime(); sTextYear:=StrPart(sReadDateToday,1,4); sTextMonth:=StrPart(sReadDateToday,6,2); sTextDay:=StrPart(sReadDateToday,9,2); nTextHour:=GetTime(\Hour); nTextMinute:=GetTime(\Min); nTextSecond:=GetTime(\Sec); sTextHour:=NumToStr(nTextHour,0); sTextMinute:=NumToStr(nTextMinute,0); sTextSecond:=NumToStr(nTextSecond,0); RETURN "Today is "+sTextYear; !RETURN "Today is "+sTextYear+"/"+sTextMonth+"/"+sTextDay+sGap+"Time "+sTextHour+":"+sTextMinute+":"+sTextSecond; ENDFUNC
Have a look at this maybe this will give you some better understanding.0
- 348 IRC5
- 845 RAPID Programming
- 21 AppStudio
