Setting your own value for incremental jogging
I've noticed in the jogging panel there are five options, None, Small, Medium, Large and User. The operating manual describes the option to set your own increment (see attached screenshot). How do I do this?
Welcome!
  • lemster68
    lemster68 ✭✭✭
    You set it in your motion parameters.  Look in system parameter manual for full description.
    Lee Justice
    Thanks, I found it. I wonder why there is an option to set your own user defined increments when the allowed values don't exceed the existing jogging options. For instance, the maximum allowed value is 0.005 meters (5mm) but the "Large" step setting is already 5mm.
  • lemster68
    lemster68 ✭✭✭
    You are welcome.  It is from .005 to 0.  0 is smaller, but I am not sure how many decimal places you can actually carry it.
    Lee Justice
    Would be really nice if I could set it to any value I want! Maybe one day
Welcome!
