Setting your own value for incremental jogging
xerim
I've noticed in the jogging panel there are five options, None, Small, Medium, Large and User. The operating manual describes the option to set your own increment (see attached screenshot). How do I do this?
You set it in your motion parameters. Look in system parameter manual for full description.Lee Justice1
lemster68 said:You set it in your motion parameters. Look in system parameter manual for full description.0
You are welcome. It is from .005 to 0. 0 is smaller, but I am not sure how many decimal places you can actually carry it.Lee Justice0
- 304 PowerPacs
- 354 IRC5
- 850 RAPID Programming
- 26 AppStudio
