Simboard without DeviceNet
Hello
I have an IRB1200 with compact controller and SaveMove2 with Profinet and Profisafe.
Now I should create a SimBoard to be able to create simulated signals.
Usually the simulated boards always hang in DeviceNet. But this is now missing.
How can I now create a simulated board?
Thanks for your support 0
You can make a new board - "MySimBoard" - Attach it to whatever network is select-able in the drop down. Then make your board "Simulated" by selecting the simulated option in the device type settings. Then add your signals to that board as required.
I think this is the easiest way for you to achieve what you want.0
