Change font color for UIMsgWrite message
Hello, i'm searching for a way to change the color of the message font showed on the FlexPendant when using the instruction UIMsgWrite, because the font is gray and the background is white and the operator can't read easly. Another good things is if there is the possibility to change the font size.
Thanks in advance for the answer
  • As YuMiAZ has described, this is a thing.  And it's puzzling.  I don't see how this would be intentional because it makes communicating with the robot operator difficult because the font is so light against the white background.  If you know something about how to deal with this, please don't leave this thread without leaving a comment.  Your help will be greatly appreciated.  Thank you!
