RapidVariable SmartComponent doesn't work - Or how to get object name to the RAPID code.
In order to do some calculations in rapid I need to know which object is first in queue, in order to feed this name to the controller I have been trying to use "RapidVariable" smart component. This does work if I manually press "Set", however if I try to do it with an I/O signal it simply does not execute.
In short - If I press set, it works. If I connect a signal to Set, it doesn't work. What could be the problem, or am I using it wrong?
  • Have you tried connecting a SR-latch before the Set?
    It could be that if the signal is a pulse, then Set isn't triggered.
    So Signal -> SR-latch -> Set.
    Maxim Riabichev
    PC Software Support Engineer
  • I have, can't get anything to work with a variable and set :/ I have done a workaround, so it is not a stressing issue anymore.
