Random function
in UpFeed
I have to create a random function that generates a number between 1 and 100 and if the number is greater than 50, do one cycle, if less than another.
How can i do using rapid code?
You could start by posting this question in the forum category for Rapid programming. This one is for robotstudio feedback.
Or you can try this:FUNC num fRandomGenerator() VAR num nRandom; VAR num nMinute; VAR num nSecond; VAR num nArrayPointer1; VAR num nArrayPointer2; ! you could also put numbers out of order within the array elements, allow duplicates if you like VAR num myNumArray10x10{10,10}:=[[1,2,3,4,5,6,7,8,9,10],[91,92,93,94,95,96,97,98,99,100],[21,22,23,24,25,26,27,28,29,30],[61,62,63,64,65,66,67,68,69,70] ,[51,52,53,54,55,56,57,58,59,60],[41,42,43,44,45,46,47,48,49,50],[31,32,33,34,35,36,37,38,39,40],[71,72,73,74,75,76,77,78,79,80] ,[81,82,83,84,85,86,87,88,89,90],[11,12,13,14,15,16,17,18,19,20]]; ! Random number generation based on minutes and seconds of system time nMinute:=GetTime(\Min); nSecond:=GetTime(\Sec); IF nMinute = 0 THEN ! Cannot point to array index 0, will cause array index out of bounds nArrayPointer1 := 1; ELSEIF nMinute >= 1 AND nMinute <= 6 THEN nArrayPointer1 := 1; ELSEIF nMinute >= 7 AND nMinute <= 12 THEN nArrayPointer1 := 2; ELSEIF nMinute >= 13 AND nMinute <= 18 THEN nArrayPointer1 := 3; ELSEIF nMinute >= 19 AND nMinute <= 24 THEN nArrayPointer1 := 4; ELSEIF nMinute >= 25 AND nMinute <= 30 THEN nArrayPointer1 := 5; ELSEIF nMinute >= 31 AND nMinute <= 36 THEN nArrayPointer1 := 6; ELSEIF nMinute >= 37 AND nMinute <= 42 THEN nArrayPointer1 := 7; ELSEIF nMinute >= 43 AND nMinute <= 48 THEN nArrayPointer1 := 8; ELSEIF nMinute >= 49 AND nMinute <= 54 THEN nArrayPointer1 := 9; ELSEIF nMinute >= 55 AND nMinute <= 60 THEN nArrayPointer1 := 10; ENDIF IF nSecond = 0 THEN ! Cannot point to array index 0, will cause array index out of bounds nArrayPointer2 := 1; ELSEIF nSecond >= 1 AND nSecond <= 6 THEN nArrayPointer2 := 1; ELSEIF nSecond >= 7 AND nSecond <= 12 THEN nArrayPointer2 := 2; ELSEIF nSecond >= 13 AND nSecond <= 18 THEN nArrayPointer2 := 3; ELSEIF nSecond >= 19 AND nSecond <= 24 THEN nArrayPointer2 := 4; ELSEIF nSecond >= 25 AND nSecond <= 30 THEN nArrayPointer2 := 5; ELSEIF nSecond >= 31 AND nSecond <= 36 THEN nArrayPointer2 := 6; ELSEIF nSecond >= 37 AND nSecond <= 42 THEN nArrayPointer2 := 7; ELSEIF nSecond >= 43 AND nSecond <= 48 THEN nArrayPointer2 := 8; ELSEIF nSecond >= 49 AND nSecond <= 54 THEN nArrayPointer2 := 9; ELSEIF nSecond >= 55 AND nSecond <= 60 THEN nArrayPointer2 := 10; ENDIF nRandom:=myNumArray10x10{nArrayPointer1,nArrayPointer2}; RETURN nRandom; ENDFUNC
I just put it together, it is yet untested, should work.Lee Justice0 -
I have been testing, it works. I like it better with the array jumbled up, like this:
VAR num myNumArray10x10{10,10}:=[[51,22,3,14,5,86,77,8,29,70],[91,42,93,74,95,16,97,38,99,90],[21,2,23,24,35,26,37,28,9,30],[61,72,83,84,65,76,67,18,79,50] ,[1,12,33,54,75,36,57,88,59,40],[41,92,43,34,45,46,17,78,49,80],[31,82,53,44,25,56,27,98,19,20],[71,62,13,94,55,66,7,48,69,10] ,[81,32,63,4,85,6,87,58,89,100],[11,52,73,64,15,96,47,68,39,60]];
Lee Justice0 -
Here, what I use:!To get Ramdom more random
LOCAL VAR num callCount;
!Get a random number between 0 and 1
LOCAL FUNC num RANDOM()
VAR num val:=1;
var pos pos_current;
pos_current := CPos(\Tool:=tool0 \WObj:=wobj0);
!1 seeding, Seed by position
val:=val*(Abs(ROUND(pos_current.x*100, \Dec:=0)) +1); !+1 to avoid mul by 0 scenario
val := 789 + val MOD 1000; !777 is just a bogus valu, since the mod might give 0
!Feel free to seed with y,z, more
!2. seeding, Seed by time
val :=val * ( GetTime(\Sec)+1);
val :=val * ( GetTime(\Min)+1);
!3 seeding, increment callcount and handle large number
callCount := callCount +1;
IF callCount > 1000 THEN
callCount := 234;
ENDIF
!finally a division to get something interesting large float number
val := val / callCount;
!get a value between 0 and 1 using COS ( math)
RETURN (0.5 + COS(val)/2);
ENDFUNC☑️2024 - RobotStudio® User Group0 -
I made a revision so that the numbers used are tracked, therefore using only once, until all have been used. Then it will be reset.
MODULE RANDOM_GEN ! REV 1, added bool array to track numbers already used, no duplicates. ! Added counter for total of numbers used ! Boolean array to keep track of which numbers have been used PERS bool bUsedArray{10,10}:=[[TRUE,TRUE,TRUE,TRUE,TRUE,TRUE,TRUE,TRUE,TRUE,TRUE],[TRUE,TRUE,TRUE,TRUE,TRUE,TRUE,TRUE,TRUE,TRUE,TRUE] ,[TRUE,TRUE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE],[FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE],[FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE] ,[FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE],[FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE],[FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE] ,[FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE],[FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE]]; ! Counter for how many total numbers, number range. In this case, 1-100 PERS num nNumbersUsed; FUNC num fRandomGenerator() VAR num nRandom; VAR num nMinute; VAR num nSecond; VAR num nArrayPointer1; VAR num nArrayPointer2; CONST num myNumArray10x10{10,10}:=[[51,22,83,14,5,86,77,8,29,70],[91,42,93,74,45,16,87,38,99,90],[21,2,23,24,35,26,37,28,89,30],[61,72,3,84,65,76,67,18,79,50] ,[1,12,33,54,75,36,57,88,59,40],[41,92,43,34,95,46,17,78,49,80],[31,82,53,44,25,56,27,98,19,20],[71,62,13,94,55,66,7,48,69,10] ,[81,32,63,4,85,6,97,58,9,100],[11,52,73,64,15,96,47,68,39,60]]; ! Random number generation based on minutes and seconds of system time nMinute:=GetTime(\Min); nSecond:=GetTime(\Sec); IF nMinute = 0 THEN ! Cannot point to array index 0, will cause array index out of bounds nArrayPointer1 := 1; ELSEIF nMinute >= 1 AND nMinute <= 6 THEN nArrayPointer1 := 1; ELSEIF nMinute >= 7 AND nMinute <= 12 THEN nArrayPointer1 := 2; ELSEIF nMinute >= 13 AND nMinute <= 18 THEN nArrayPointer1 := 3; ELSEIF nMinute >= 19 AND nMinute <= 24 THEN nArrayPointer1 := 4; ELSEIF nMinute >= 25 AND nMinute <= 30 THEN nArrayPointer1 := 5; ELSEIF nMinute >= 31 AND nMinute <= 36 THEN nArrayPointer1 := 6; ELSEIF nMinute >= 37 AND nMinute <= 42 THEN nArrayPointer1 := 7; ELSEIF nMinute >= 43 AND nMinute <= 48 THEN nArrayPointer1 := 8; ELSEIF nMinute >= 49 AND nMinute <= 54 THEN nArrayPointer1 := 9; ELSEIF nMinute >= 55 AND nMinute <= 60 THEN nArrayPointer1 := 10; ENDIF IF nSecond = 0 THEN ! Cannot point to array index 0, will cause array index out of bounds nArrayPointer2 := 1; ELSEIF nSecond >= 1 AND nSecond <= 6 THEN nArrayPointer2 := 1; ELSEIF nSecond >= 7 AND nSecond <= 12 THEN nArrayPointer2 := 2; ELSEIF nSecond >= 13 AND nSecond <= 18 THEN nArrayPointer2 := 3; ELSEIF nSecond >= 19 AND nSecond <= 24 THEN nArrayPointer2 := 4; ELSEIF nSecond >= 25 AND nSecond <= 30 THEN nArrayPointer2 := 5; ELSEIF nSecond >= 31 AND nSecond <= 36 THEN nArrayPointer2 := 6; ELSEIF nSecond >= 37 AND nSecond <= 42 THEN nArrayPointer2 := 7; ELSEIF nSecond >= 43 AND nSecond <= 48 THEN nArrayPointer2 := 8; ELSEIF nSecond >= 49 AND nSecond <= 54 THEN nArrayPointer2 := 9; ELSEIF nSecond >= 55 AND nSecond <= 60 THEN nArrayPointer2 := 10; ENDIF WHILE nRandom = 0 DO IF NOT bUsedArray{nArrayPointer1,nArrayPointer2} THEN nRandom:=myNumArray10x10{nArrayPointer1,nArrayPointer2}; bUsedArray{nArrayPointer1,nArrayPointer2}:=TRUE; ELSE FOR i FROM 1 TO 10 DO FOR j FROM 1 TO 10 DO IF bUsedArray{i,j} = FALSE THEN bUsedArray{i,j}:= TRUE; nRandom:=myNumArray10x10{i,j}; IF (i <= 10) AND (j <= 10) THEN IF nRandom = 0 STOP; Incr nNumbersUsed; ! all of the array positions have been used, this is the ! last one, time to reset all to FALSE IF nNumbersUsed = 100 ResetBool; RETURN nRandom; ENDIF ENDIF ENDFOR ENDFOR ENDIF ENDWHILE IF nRandom = 0 STOP; Incr nNumbersUsed; ! all of the array positions have been used, this is the ! last one, time to reset all to FALSE IF nNumbersUsed = 100 ResetBool; RETURN nRandom; ENDFUNC PROC testFunc() VAR num nTest; nTest:=fRandomGenerator(); TPWrite "Random number generated is: "\Num:=nTest; WaitTime 5; ENDPROC PROC ResetBool() FOR i FROM 1 TO 10 DO FOR j FROM 1 TO 10 DO bUsedArray{i,j}:=FALSE; ENDFOR ENDFOR nNumbersUsed:=0; ENDPROC ENDMODULE
Lee Justice0 -
I noticed today that I left some of the bUsed array TRUE after I had been testing. If you would like to use this code please make sure that you make them all FALSE first. Too late for me to edit that post.Lee Justice0
Nowadays you can use Rand()-----------------
David
- 361 IRC5
- 78 OmniCore
- 852 RAPID Programming
- 30 AppStudio
