Home› Robot Controller
DSQC 355A Pins
  • Mute
duesentrieb66
duesentrieb66 ✭
June 2020 in Robot Controller
Hello all,
is there a drawing where I can see how to connect the analog I/O for the DSQC 355A?
  • graemepaulin
    graemepaulin mod
    June 2020
    No drawing but pin out in the attached from the DeviceNet manual
    DSQC355A.pdf 411.6K
  • duesentrieb66
    duesentrieb66 ✭
    August 2020
    Thank you
  • All Categories
  • 5.6K RobotStudio
  • 399 UpFeed
  • 20 Tutorials
  • 14 RobotApps
  • 301 PowerPacs
  • 406 RobotStudio S4
  • 1.8K Developer Tools
  • 250 ScreenMaker
  • 2.8K Robot Controller
  • 345 IRC5
  • 73 OmniCore
  • 8 RCS (Realistic Controller Simulation)
  • 843 RAPID Programming
  • 20 AppStudio
  • 4 RobotStudio AR Viewer
  • 19 Wizard Easy Programming
  • 107 Collaborative Robots
  • 5 Job listings
In this Discussion
  • August 2020 duesentrieb66
  • June 2020 graemepaulin
