How to attach object to source copy object?
slavenp
How can I attach one object to object created by Souce component in SmartComponent?
I can't find that component listed in event manager because it's created once simulation is started and every time it has different name..
Any solution for this?
I'm using older version of RobotStudio (5.15.02).
you should use smart components, instead of event manager1
Thanks for this. I was looking for the solution and finally found it.svoldgaard said:you should use smart components, instead of event manager0
- 42 AppStudio
