How do you link a rapid pers to an i/o group output?
Thanks.0
You assign it: nCurrProgIndex:=B1ProgIndex;Lee Justice0
This created a syntax error because it was in a system module.0
It should not matter that it is a system module. I see that you made an AliasIO but it also looks like it is configured as an actual Group output. I don't see the need right now for the AliasIO.Lee Justice0
My bad, I had to do some checking. nCurrProgIndex:=GOutput(B1ProgIndex);Lee Justice0
