Trouble with Interupt
I'm trying to use interrupt but i guet some problem and i hope you could help me.
We are using multimove system with irb6400
First interrupt have to stop the robot until we restart with signal from PLC.
Is it Okay ? sometime i got queue interupt is full... i don't know why
TRAP Interrupt_R1
TPWrite "Robot 1 - STOP";
StopMove;
IDelete robot1_stop;
WaitDI PN_DI020,1;
StartMove;
CONNECT robot1_stop WITH Interrupt_R1;
ISignalDI PN_DI015,1,robot1_stop;
ENDTRAP
The second interrupt should do :
- stop the movement on the path
- Move the robot to another position
- Wait signal to restart
TRAP Interrupt_CasseLame_R1
Set PN_DO133;
StopMove;
ClearPath;
Ouverture_Galets_R1;
TPWrite" Casse lame robot1 ";
StartMove;
posAct_R1:=CRobT(\Tool:=tool_lame_R1_2\WObj:=wobj0);
MoveL RelTool(posAct_R1,0,-150,0),v300,fine,tool_lame_R1_2\WObj:=wobj0;
TPWrite" Coupez le PVB puis appuyez sur PLAY apres fermeture porte ";
IDelete robot1_CasseLame;
Stop;
Main;
ENDTRAP
But i got an error the pointer of the robot is too far from the cursor.. What can i do ?
Regards
Regards
For the first TRAP the solution is to not disconnect and reconnect the interruptTRAP Interrupt_R1TPWrite "Robot 1 - STOP";StopMove;WaitDI PN_DI020,1;StartMove;ENDTRAP0
Use the instruction ISleep first in your trap. If you do not, it keeps triggering, causing interrupt queue full.Lee Justice0
- 339 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
