Create file, then save to network location
I'm currently working on logging data from our welding robot (Arc ONtime, program execution time etc.), and would like for the program to write the logged data to a file saved on our server.
My question:
Is it possible to write RAPID code that saves some amount of data in a file, and then saves it on a network location?
  • jmf
    jmf
    edited September 2020
    Did you get this sorted?
    I haven't had time to look further into solving this problem, as other more important problems came up in the meantime. I downloaded the script you made, but I won't know when I'll have time to look at it again. Thank you for your suggestion
