Upgrading Robotware from 5.61 to 6.11 on IRC5 controller
Hi there, I really hope someone can help out with this as I have been struggling with it for over 2 weeks now. I have bought an upgrade for Robotware from 5.61 to 6.11. The ABB people sent me over a new system and a migrated backup. I have RobotStudio 6.06 installed on my computer. I have been trying to 'upload' this upgrade onto my IRC5 controller and it just won't have it. I tried different methods, using Installation Manager, using System Builder, even tried to do it via the teach pendant by simply going to Backup & Restore and trying to restore the migrated backup onto the controller. Nothing works. I keep getting this error when I try to restore it that the EIO.cfg is incorrect/has errors. Trying to use the Installation Manager app, the controller doesn't even show up in the list. For some reason Installation Manager cannot see it, with or without me being connected to the controller via RobotStudio. I am running out of ideas here. I tried to ask ABB for help with this as this upgrade was purchased but that didn't get me anywhere. Has anyone else had this issue before and knows what to do about it? Thank you so much in advance!
For reference, the Migration Manual is located here:
Controller Tab - Installation Manager - Migrate Robotware - Migration Checklist.
5
In the Installation Manger manual it gives a description of the changes made when migrating the EIO.cfg. Confirm if the Header is as described in the manual.
Hi Jmf,
Thank you for your response! This might be the issue as they are different. Mine is EIO:CFG_1 rather than EIO:CFG1. I will modify it to be with the correct header. I hope this will make it work! Thank you again!0 -
Hi again, It did not seem to do it unfortunately
may I ask where are you seeing the Installation Manager manual? It looks like it is RobotStudio but I do not seem to be able to find that page on my RobotStudio... Many thanks in advance!
d_sawyer said:Hi again, It did not seem to do it unfortunately
Yes, I did...0
To get the instruction manual in the robot studioController -> Installation Manager-> Migrate Robotwere-> Migration CheckList0 -
I suggest that you first check that you have RW 6.11 in your list of installed robotwares. I would also use a newer version of robotstudio, 2019 or 2020.Lee Justice0
Hi Lemster68, thank you for your reply. I did check that. It is installed there. I am now using robotstudio 2020 but with no better results.0
Amanda96 said:d_sawyer said:Hi again, It did not seem to do it unfortunately
To get the instruction manual in the robot studioController -> Installation Manager-> Migrate Robotwere-> Migration CheckList)
I would also check that RW 6.11 is compatible with the version of main computer in your controller. For example, I think that the oldest is DSQC609, no way could you upgrade to this high a version.Lee Justice0
Main computer is DSQC662. I didn't find anything online telling me that I cannot upgrade to 6.11 with this particular computer...? where would one find the compatibilities list? thank you in advance!0
DSQC662 is a power supply, NOT a main computer. The main computer which supports RW6.00~6.11 is DSQC 1000, DSQC1018 and DSQC1024.0
innebandy said:DSQC662 is a power supply, NOT a main computer. The main computer which supports RW6.00~6.11 is DSQC 1000, DSQC1018 and DSQC1024.0
I have to ask because you have said that the installation manager does not see the controller. Have you used the installation manager to first CREATE the system? Then you would need to connect to the controller to download it. You should also be able to put it onto a usb drive from which you could install the system.Lee Justice0
lemster68 said:I have to ask because you have said that the installation manager does not see the controller. Have you used the installation manager to first CREATE the system? Then you would need to connect to the controller to download it. You should also be able to put it onto a usb drive from which you could install the system.0
OK, make a new system, not virtual. As far as your IP settings go, use DHCP, the controller will assign you an IP address when you connect to the service port. Let us know how it goes.Lee Justice0
Hi everyone! just to give you an update, an ABB engineer came in today to have a look. The only thing he did differently was use RS 6.09 rather than RS 2020. He then was able to see the controller under Installation Manager - Network and everything was quite straightforward from there. He did however install RW 6.09 and not 6.11. Sorry if this is not the fix people were hoping for. It seems that RS 2020 was more to blame than anything else. Thank you all for all your help and support!0
- 348 IRC5
- 844 RAPID Programming
- 21 AppStudio
