Universal data type Function
Could you explain some more? I do not fully understand. If the array contains something in particular, or just has data, not null values.Lee Justice0
I am sorry.lemster68 said:Could you explain some more? I do not fully understand. If the array contains something in particular, or just has data, not null values.
I have function which returns TRUE if num array contains specific number. Like this, for example:FUNC bool IfArrayContains(num nArray{*}, num nValue)VAR bool contains:=FALSE;VAR num i := 1;WHILE i<=Dim(nArray, 1) AND contains=FALSE DOIF nArray{i}=nValue THENcontains:=TRUE;ENDIFincr i;ENDWHILERETURN contains;ENDFUNC
And my target is to make this function universal for multiple datatypes.
Something like this:FUNC bool IfArrayContains(ANYTYPE# Array{*}, ANYTYPE# Value)IF Type(Array)=Type(Value) THEN............ELSEIF .......................
And so on.
OK, so you do not necessarily need ALL datatypes, just some? You could use switch parameters and the function Present() to see which types were passed in. I would also suggest to change your WHILE into FOR loop.Lee Justice0
in other words, I want ANYTYPE# as an input parameter
But it causes syntax error.0 -
Yes, I thought about it, but it's ugly. It would be easier to have one implicit parameter and call the Type() function with it.lemster68 said:OK, so you do not necessarily need ALL datatypes, just some? You could use switch parameters and the function Present() to see which types were passed in. I would also suggest to change your WHILE into FOR loop.
Edit: And yes, you are right. Put RETURN into FOR loop is better.0 -
I was suggesting switch type argument, not in parameter. How many datatypes do you want? Just some or All?
Lee Justice0 -
I mean this.0 -
OK, you really got me thinking now. Let's start by making a record of all the datatypes.
A parameter reference may mean the entire parameter, an element of a parameter (array) or a component of a parameter (record).
If they are all listed in a record, then you can pass it in as a component of the record which lists all datatypes.
Next issue is the second parameter...Lee Justice0 -
So what you are seeing there is that IF you use an atomic type, THEN it can be anytype. Not that there is an anytype#. I started something in RS with the Record, man there are a lot of types! Too many and most would be of no use to check (In my opinion). It was not working like that anyway. So I went back to my earlier suggestion of using switches, you do not have to use all of them, just the one you want. As a matter of fact, you do not have to use any of them. But then the function will do nothing. I put together a little template with three common datatypes which I seem to think that you would want to check. Here it is:
FUNC bool check(\switch swbool,\switch swTRUE|switch swFALSE, \switch swnum, num nArray{*}, VAR num nValue, \switch swString, VAR string stArray{*}, VAR string stString) IF Present(swbool) THEN ! this is one way to do it with more switches ! simple for bool operation IF Present(swTRUE) THEN ! evaluate here to match the value for TRUE ELSEIF Present(swFalse) THEN ! evaluate here to match the value for FALSE ENDIF ENDIF IF Present(swnum) THEN ! evaluate here to match the value passed by nValue FOR i FROM 1 TO Dim(nArray, 1) DO IF nArray{i}=nValue THEN RETURN TRUE; ENDIF ENDFOR ENDIF IF Present(swString) THEN ! evaluate here to match the value passed by stString FOR i FROM 1 TO Dim(stArray, 1) DO IF stArray{i}=stString THEN RETURN TRUE; ENDIF ENDFOR ENDIF ENDFUNC
Lee Justice0 -
Yes, I used something similar to what you put here. Sure, there are a lot of useless types. Good point. So, commonly used atomic types (num, dnum, string - bool is useless because it has only 2 values and so there is no need to look for a specific value in the array - other types are aliases that can be interchanged or non-value data types - RECORD types like robtarget , jointtarget, etc., you usually don't need to store them in array and look for a specific value), I thought I could use some reference or implicit data type or something. But I did some research and it's not possible. Anyway, thank you for your help.0
You are quite welcome.Lee Justice0
