Variable num from pose
Hello!
After Search_1D I have offset values in
LOCAL PERS pose a:=[[x,y,z],[1,0,0,0]];.
LOCAL PERS pose b:=[[x,y,z],[1,0,0,0]];.
How I can extract values X from poses for variables num A, B?
A:=......???
B:=......???
It’s needed for use in command ArcC RelTool(p45,A,0,0),RelTool(p90,B,0,0)......
Or may be I have mistake and you have more simple or more good variant.
  • A:=pose_a.trans.x;
    B:=pose_b.trans.x;
  • So, I tried this, but it doesn’t work.
  • Mehelgi said:
    Hello!
    A:=......???
    B:=......???
    It might be because of your declaration. No spaces between declarations naming's. Controller doesn't like it.
    Also remove the "." after the declarations.
    Should be:
    LOCAL PERS pose_a:=[[0,0,0],[1,0,0,0]];
    LOCAL PERS pose_b:=[[0,0,0],[1,0,0,0]];
  • Values after Search_1D:
    LOCAL PERS pose pePAT_OK_0:=[[-0.128607,-1.93481,-0.960388],[1,0,0,0]];
    Declaration p_0_x:
    LOCAL VAR num p_0_x:=0;
    After Search_1D:
    p_0_x:=pePAT_OK_0.trans.x;
    ArcLStart RelTool(p0,p_0_x,p_0_y,p_0_z),v200,seam1,weld9\Weave:=weave7,fine,tWeldGunCMT45\WObj:=wobjSTN2;
  • What errors do you get?
  • The value doesn't change and the trajectory doesn't change too.
  • Try to change it to a pers and do it after the search and before the rob movement.
  • The first post has a valid declaration of the pose, it is merely A and B, pose indicates data type.  You do not have to break it down to the atomic level with x, y and z to assign the values, see below:
    VAR pos myPos:=[0,0,0];
    myPos:=A.trans;
    MoveL RelTool(myPick,myPos.x,myPos.y,myPos.z), speed, tool, blah, blah;
    To use those values in the RelTool, however, you must break it down as seen above.
    Lee Justice
  • So, I cut declaration part (p_0_x:=pePAT_OK_0.trans.x;) from search_routine and moved it into welding_routine before Arc commands. And now everything worked.
    Thank you very much for your help!
