Universal data type Function
I am trying to create universal function to check if array contains something. Parameters should be of any type, how "Present(ANYTYPE# DatObj)" function works, for example.
Is this possible?
Thank you
D.V.
Welcome!
  • Could you explain some more?  I do not fully understand.  If the array contains something in particular, or just has data, not null values.
    Lee Justice
  • dvlcek
    dvlcek
    edited September 2020
    I am sorry.
    I have function which returns TRUE if num array contains specific number. Like this, for example:
    FUNC bool IfArrayContains(num nArray{*}, num nValue)
    VAR bool contains:=FALSE;
    VAR num i := 1;
    WHILE i<=Dim(nArray, 1) AND contains=FALSE DO
    IF nArray{i}=nValue THEN
    contains:=TRUE;
    ENDIF
    incr i;
    ENDWHILE
    RETURN contains;
    ENDFUNC
    And my target is to make this function universal for multiple datatypes.
    Something like this:
    FUNC bool IfArrayContains(ANYTYPE# Array{*}, ANYTYPE# Value)
    IF Type(Array)=Type(Value) THEN
    ELSEIF .......................
    And so on.
  • OK, so you do not necessarily need ALL datatypes, just some?  You could use switch parameters and the function Present() to see which types were passed in.  I would also suggest to change your WHILE into FOR loop.
    Lee Justice
  • in other words, I want ANYTYPE# as an input parameter :)
    But it causes syntax error.
  • dvlcek
    dvlcek
    Yes, I thought about it, but it's ugly. It would be easier to have one implicit parameter and call the Type() function with it.
    Edit: And yes, you are right. Put RETURN into FOR loop is better.
  • I was suggesting switch type argument, not in parameter.  How many datatypes do you want?  Just some or All?
    Lee Justice
  • dvlcek
    dvlcek
    All of them. The idea is to have one universal function for all datatypes.
    Post edited by dvlcek on
  • I mean this.
  • OK, you really got me thinking now.  Let's start by making a record of all the datatypes.
    A parameter reference may mean the entire parameter, an element of a parameter (array) or a component of a parameter (record).
    If they are all listed in a record, then you can pass it in as a component of the record which lists all datatypes.
    Next issue is the second parameter...
    Lee Justice
  • So what you are seeing there is that IF you use an atomic type, THEN it can be anytype.  Not that there is an anytype#.  I started something in RS with the Record, man there are a lot of types!  Too many and most would be of no use to check (In my opinion).  It was not working like that anyway.  So I went back to my earlier suggestion of using switches, you do not have to use all of them, just the one you want.  As a matter of fact, you do not have to use any of them.  But then the function will do nothing.  I put together a little template with three common datatypes which I seem to think that you would want to check.  Here it is:
    FUNC bool check(\switch swbool,\switch swTRUE|switch swFALSE, \switch swnum, num nArray{*}, VAR num nValue, \switch swString, VAR string stArray{*}, VAR string stString)
            IF Present(swbool) THEN
              ! this is one way to do it with more switches
              ! simple for bool operation
              IF Present(swTRUE) THEN
                ! evaluate here to match the value for TRUE
              ELSEIF Present(swFalse) THEN
                ! evaluate here to match the value for FALSE
              ENDIF
            ENDIF
            IF Present(swnum) THEN
              ! evaluate here to match the value passed by nValue
              FOR i FROM 1 TO Dim(nArray, 1) DO
                  RETURN TRUE;
                ENDIF
              ENDFOR
            ENDIF
            IF Present(swString) THEN
              ! evaluate here to match the value passed by stString
              FOR i FROM 1 TO Dim(stArray, 1) DO
                IF stArray{i}=stString THEN
                  RETURN TRUE;
                ENDIF
              ENDFOR
            ENDIF
        ENDFUNC
    Lee Justice
  • Yes, I used something similar to what you put here. Sure, there are a lot of useless types. Good point. So, commonly used atomic types (num, dnum, string - bool is useless because it has only 2 values ​​and so there is no need to look for a specific value in the array - other types are aliases that can be interchanged or non-value data types - RECORD types like robtarget , jointtarget, etc., you usually don't need to store them in array and look for a specific value), I thought I could use some reference or implicit data type or something. But I did some research and it's not possible. Anyway, thank you for your help.
  • You are quite welcome.
    Lee Justice
Welcome!
