Hidden massage on Virtual Flexpendant
Tomaz
When I try to switch on Virtual Flexpendant from manual mode to auto mode, I get first warning window. After confirming warning I should get window to acknowledge swithing from manual to auto but I can't get it.
Hi Tomaz,
This will be fixed in RobotStudio 5.08.
regards,
Johannes
Johannes Weiman
How can I confirm Auto mode?
regards,
Tomaz
Hi Tomaz,
See the attached file for an updated component that should solve this problem in RS 5.07.01. Unzip the dll to the <program files>ABB Industrial ITRobotics ITRobotStudioin directory (backup the original file first).
2007-01-25_160456_LgVCHelper.zip
Please note that this is provided "as-is", without warranty of any kind, etc.
Johannes Weiman
ABB Robotics0
