RAPID funtion to remove white space
Is there a function that will remove all leading white space in a string?
Something equivalent to string.Trim() in c#
You could write your own, or perhaps a routine. There is a predefined data, STR_WHITE, for blank space. There are a lot of string functions available and I suppose you could use one or more to clear out any undesired white spaces.Lee Justice0
FUNC string StrTrim(string sInput, string sTrim)VAR string sPart;VAR string sReturn;FOR i FROM 1 TO StrLen(sInput) DOsPart:=StrPart(sInput,i,1);IF sPart<>sTrim sReturn:=sReturn+sPart;ENDFORRETURN sReturn;ENDFUNC
Needed and created it last week.Cheers0
