RAPID funtion to remove white space
Is there a function that will remove all leading white space in a string?
Something equivalent to string.Trim() in c#
  • You could write your own, or perhaps a routine.  There is a predefined data, STR_WHITE, for blank space.  There are a lot of string functions available and I suppose you could use one or more to clear out any undesired white spaces.
    Lee Justice
  •   FUNC string StrTrim(string sInput, string sTrim)
        VAR string sPart;
        VAR string sReturn;
          FOR i FROM 1 TO StrLen(sInput) DO
            sPart:=StrPart(sInput,i,1);
            IF sPart<>sTrim sReturn:=sReturn+sPart;
          ENDFOR
          RETURN sReturn;
      ENDFUNC
    Needed and created it last week.
    Cheers
