What's the best way to add a comment on FlexPendant?
What's best way to add a comment when programming on the flexpendent?
I can see how to comment an instruction, which I can then edit, but it seems a bit of a workaround.
Cheers, Joe.
  • Micky
    Micky ✭✭✭
    to add a comment you have to add a new instruction and select "Comment" in the palette "Various" on the right side.
    An empty comment is added.
    Then you change to menu "Edit" and press the button "ABC..." to enter the text of your comment.
    BR
    Micky
  • Hello,
    In Program Editor, Add Instruction,Various, Comment.
  • Is there a direct way to insert empty line on the FlexPendant?
  • DenisFR
    DenisFR ✭✭✭
    I don't think so.
    Prefer add empty comment line.
